Gostaria de saber se o curso de SEO para negócios. Atenderia site imobiliário?
Sim. Com certeza.
Obrigado pela resposta.
Comecei a Instalar o site é o recebi as mensagens abaixo, como resolvo?
Adding repository for MySQL, please wait…
Adding repository for NGINX, please wait…
Updating apt-cache [OK]
Oops Something went wrong!! […]
Check the WordOps log for more details tail /var/log/wo/wordops.log
and please try again…
root@cloud:~# tail /var/log/wo/wordops.log
- Filesize:679896 [weak]
E: Failed to fetch https://provo-mirror.opensuse.org/repositories/home%3A/virtub ox%3A/WordOps/Debian_11/amd64/nginx-custom_1.24.0-1ppa~stable_amd64.deb File ha s unexpected size (679880 != 679896). Mirror sync in progress? [IP: 2a07:de40:40 1::70 443]
Hashes of expected file:
- SHA256:75d578203f0e3d9a85b3be73c8b3ce64ba1016007be92bccbee730d71ad947ec
- SHA1:4434761e283db83ae5ebf89d6585b8d0733393ee [weak]
- MD5Sum:3070996b2177e79d49df33944254c63e [weak]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
2024-02-17 12:22:11,914 (INFO) wo : Oops Something went wrong!!
2024-02-17 12:22:11,914 (ERROR) wo : Check the WordOps log for more detailstai l /var/log/wo/wordops.log
Verifica se utilizou o Debian 12.
Atualmente é necessário trabalhar com Debian 12 ou Ubuntu 22
Caso não seja esse o problema, abre um novo tópico sobre o assunto.
Resolvi utilizando o Debian 12, muito obrigado!
