Tudo começou quando eu fui instalar um plugin, ai ele não dava o rebuild dps de eu colocar o plugin, ai so sei que eu fiz tanta besteira desesperado pra ele voltar que ele não voltou e aparece isso
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [[email protected]]: [email protected]
Sending mail to [email protected]. . .
Testing sending to [email protected] using email-smtp.us-east-1.amazonaws.com:25, username:AKIAXNIRTOG44HOGD4XX with plain auth.
======================================== ERROR ========================================
UNEXPECTED ERROR
Timeout to open TCP connection to email-smtp.us-east-1.amazonaws.com:25 (exceeds 5 seconds)
====================================== SOLUTION =======================================
This is not a common error. No recommended solution exists!
Please report the exact error message above to https://meta.discourse.org/
(And a solution, if you find one!)
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Would you like to serve a publicly available version of this file? (Y/n)y
Publicly available log not generated.
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
BUT FIRST, make sure that you know the first three commands below!!!
