Fala pessoal, tudo certo?
Uma pequena dúvida, o que leva o Mautic a quebrar as imagens dessa maneira do print? Estava tudo certo até dois dias, parou do nado. Meu vhost até está configurado corretamente conforme as aulas do curso e o mesmo tipo que uso em outras duas instalações que está tudo funcionando correto.
server {
listen 80;
listen [::]:80;
listen 443 quic;
listen 443 ssl;
listen [::]:443 quic;
listen [::]:443 ssl;
http2 on;
http3 off;
{{ssl_certificate_key}}
{{ssl_certificate}}
server_name marketing.grupowisedata.com;
{{root}}
{{nginx_access_log}}
{{nginx_error_log}}
if ($scheme != “https”) {
rewrite ^ https://$host$request_uri permanent;
location ~ /.well-known {
auth_basic off;
allow all;
{{settings}}
rewrite ^/index.php/(.*) /$1 permanent;
location ~ ^/(config|tmp|core|lang) {
return 403;
location ~ /.ht {
return 403;
location ~ (.*).gif {
try_files $uri /index.php?$args;
location ~ (.*).js {
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection “1; mode=block”;
add_header X-Permitted-Cross-Domain-Policies master-only;
add_header Referrer-Policy same-origin;
add_header alt-svc ‘h3=“:443”; ma=86400’;
try_files $uri $uri/ /index.php?$args;
index index.php index.html;
location ~ .php$ {
include fastcgi_params;
fastcgi_intercept_errors on;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
try_files $uri =404;
fastcgi_read_timeout 3600;
fastcgi_send_timeout 3600;
fastcgi_param HTTPS $fastcgi_https;
fastcgi_pass 127.0.0.1:{{php_fpm_port}};
fastcgi_param PHP_VALUE “{{php_settings}}”;
location ~* ^.+.(css|js|jpg|jpeg|gif|png|ico|gz|svg|svgz|ttf|otf|woff|woff2|eot|mp4|ogg|ogv|webm|webp|zip|swf)$ {
add_header Access-Control-Allow-Origin “*”;
expires max;
access_log off;
if (-f $request_filename) {
break;
