ailton
1
Olá, ao configurar o nginx para o Mautic, esta apresentando este erro abaixo.
wget https://academy.gerenciandoweb.com.br/downloads/mautic/mautic-php74.conf
–2025-10-30 13:26:06-- https://academy.gerenciandoweb.com.br/downloads/mautic/mautic-php74.conf
Resolving academy.gerenciandoweb.com.br (academy.gerenciandoweb.com.br)… 2a06:98c1:3121::3, 2a06:98c1:3120::3, 188.114.96.3, …
Connecting to academy.gerenciandoweb.com.br (academy.gerenciandoweb.com.br)|2a06:98c1:3121::3|:443… connected.
HTTP request sent, awaiting response… 403 Forbidden
2025-10-30 13:26:06 ERROR 403: Forbidden.
Onde será que estou errando?
Estou usando a versão 4.4.13 (ultima)
Hospedado na hetzner com Ubuntu
Não está errando.
Por algum motivo meu servidor esta bloqueando o download.
Neste caso, vamos criar ele manualmente.
Usa:
nano /var/www/dominio.com/conf/nginx/mautic-php74.conf
Cola o conteúdo abaixo e salva:
######Configuração do Mautic inicio############
charset utf-8;
# redirect index.php to root
rewrite ^/index.php/(.*) /$1 permanent;
#redirect some entire folders
rewrite ^/(vendor|translations|build)/.* /index.php break;
location / {
try_files $uri /index.php$is_args$args;
location ~ \.php$ {
try_files $uri =404;
include fastcgi_params;
fastcgi_pass php74;
location = /mtracking.gif {
expires off;
gzip off;
default_type "image/gif";
add_header 'Access-Control-Allow-Origin' *;
try_files $uri /index.php?$args;
# Mautic tracking code
location = /mtc.js {
expires off;
default_type "application/javascript";
try_files $uri $uri/ /index.php$is_args$args;
# Embedded forms
location = /form/generate.js {
expires off;
#Deny everything else in /app folder except Assets folder in bundles
location ~ /app/bundles/.*/Assets/ {
allow all;
access_log off;
location ~ /app/ { deny all; }
#Deny all php files in themes folder
location ~* ^/themes/(.*)\.php {
deny all;
#Don't log robots
location = /robots.txt {
access_log off;
log_not_found off;
#Deny yml, twig, markdown, init file access
location ~* /(.*)\.(?:markdown|md|twig|yaml|yml|ht|htaccess|ini)$ {
deny all;
access_log off;
log_not_found off;
#Deny hidden files
location ~ /\.(?!well-known\/) {
deny all;
###############Fim Mautic#############
