Erro ao instalar WordOps
Olá Gabriel e amigos.
Estou tentando instalar o WordOps num server CONTABO, UBUNTU 20.04 e após a instalação, não consigo fazer nada, instalar WP nem pacotes, na instalação já aparece assim:
Welcome to WordOps install/update script v3.16.2
Installing wo dependencies [OK]
Installing WordOps [OK]
Running post-install steps [OK]
WordOps (wo) require an username & and an email address to configure Git (used t o save server configurations)
Your informations will ONLY be stored locally
Enter your name: Suporte
Enter your email: wordpress@siteasy.com.br
sys.exit(main())
File “/opt/wo/lib/python3.8/site-packages/wo/cli/main.py”, line 93, in main
with app:
File “/opt/wo/lib/python3.8/site-packages/cement/core/foundation.py”, line 150 1, in enter
self.setup()
File “/opt/wo/lib/python3.8/site-packages/cement/core/foundation.py”, line 852 , in setup
self._setup_plugin_handler()
File “/opt/wo/lib/python3.8/site-packages/cement/core/foundation.py”, line 133 9, in _setup_plugin_handler
self.plugin.load_plugins(self.plugin.get_enabled_plugins())
File “/opt/wo/lib/python3.8/site-packages/cement/ext/ext_plugin.py”, line 290, in load_plugins
self.load_plugin(plugin_name)
File “/opt/wo/lib/python3.8/site-packages/cement/ext/ext_plugin.py”, line 259, in load_plugin
if self._load_plugin_from_bootstrap(plugin_name, self.bootstrap):
File “/opt/wo/lib/python3.8/site-packages/cement/ext/ext_plugin.py”, line 225, in _load_plugin_from_bootstrap
import(full_module, globals(), locals(), [], 0)
File “/opt/wo/lib/python3.8/site-packages/wo/cli/plugins/debug.py”, line 11, i n
from wo.cli.plugins.site_functions import logwatch
File “/opt/wo/lib/python3.8/site-packages/wo/cli/plugins/site_functions.py”, l ine 12, in
from wo.cli.plugins.sitedb import getSiteInfo
File “/opt/wo/lib/python3.8/site-packages/wo/cli/plugins/sitedb.py”, line 6, i n
from wo.cli.plugins.models import SiteDB
File “/opt/wo/lib/python3.8/site-packages/wo/cli/plugins/models.py”, line 3, i n
from wo.core.database import Base
File “/opt/wo/lib/python3.8/site-packages/wo/core/database.py”, line 9, in
engine = create_engine(WOVar.wo_db_uri, convert_unicode=True)
File “”, line 2, in create_engine
File “/opt/wo/lib/python3.8/site-packages/sqlalchemy/util/deprecations.py”, li ne 277, in warned
return fn(*args, **kwargs) # type: ignore[no-any-return]
File “/opt/wo/lib/python3.8/site-packages/sqlalchemy/engine/create.py”, line 6 93, in create_engine
raise TypeError(
TypeError: Invalid argument(s) ‘convert_unicode’ sent to create_engine(), using configuration SQLiteDialect_pysqlite/QueuePool/Engine. Please check that the ke yword arguments are appropriate for this combination of components.
WordOps (wo) installed successfully
To enable bash-completion, just use the command:
bash -l
To install WordOps recommended stacks, you can use the command:
wo stack install
To create a first WordPress site, you can use the command:
wo site create site.tld --wp
WordOps Documentation : https://docs.wordops.net
WordOps Community Forum : https://community.wordops.net
WordOps Community Chat : https://chat.wordops.net
Give WordOps a GitHub star : https://github.com/WordOps/WordOps/
Pode me ajudar?
Obrigado!
Também me deparei com esse erro na última madrugada.
Fiz alguns testes e relação com alguns novos pacotes dos sistemas Debian e Ubuntu.
Vai precisar de uma atualização do WordOps para resolver.
Acredito que vai ser resolvido nas próximas horas.
Entendi, achei estranho pois instalei um server nas mesmas condições semana passada e deu tudo certo, estava tentando achar onde eu estava errando.
Obrigado Gabriel, vou acompanhar e volto quando tiver resolvido.
Se eu tiver uma novidade sobre também posto aqui.
Gabriel, com esse erro e melhor fazer um novo servidor, quando td estiver ok?
Uma alternativa imediata seria clonar um server existente.
Mas recomendaria aguardar até resolver.
Fiz alguns novos testes instalando versões anteriores do WordOps e retornou o mesmo erro.
Já tem relatos sobre no fórum do WordOps e no GitHub do WordOps.
Acredito que vai ser resolvido muito em breve.
Pessoal.
Hoje foi lançada a nova versão do WordOps.
Acredito que o problema foi resolvido.
Se alguém enfrentar dificuldades por favor me avisem.
Acabei de fazer um teste.
Tudo funcionado perfeitamente.
Testei aqui também, 100%, muito obrigado Gabriel!
