Boa noite. Estava analisando log de erro ao tentar ativar o fast cgi como comando wo site update dominio.tld --wpfc.
root@server:/etc/nginx/sites-enabled# wo site update sanocorp.com.br --wpfc
Running pre-update checks [OK]
Backup location : /var/www/sanocorp.com.br/backup/06Apr2021-21-40-28
Backing up database [Fail]
Check the log for details: tail /var/log/wo/wordops.log and please try again
Abaixo o log (é um erro de sintaxe do script ? )
root@server:/etc/nginx/sites-enabled# nano /var/log/wo/wordops.log
- GNU nano 2.7.4 File: /var/log/wo/wordops.log*
^[[36m2021-04-06 21:40:30,730 (DEBUG) wo.core.logging : ^[[95mSetting apt_packages variable for MySQL^[[0m
^[[36m2021-04-06 21:40:30,730 (DEBUG) wo.core.logging : ^[[95mRunning command: /usr/bin/mysqladmin ping^[[0m
^[[36m2021-04-06 21:40:30,739 (DEBUG) wo.core.logging : ^[[95mCommand Output: mysqld is alive
Command Error: ^[[0m
^[[36m2021-04-06 21:40:30,739 (DEBUG) wo.core.logging : ^[[95mSetting packages variable for WP-CLI^[[0m
^[[36m2021-04-06 21:40:30,739 (DEBUG) wo.core.logging : ^[[95m’Namespace’ object has no attribute ‘web’^[[0m
^[[32m2021-04-06 21:40:30,740 (INFO) wo : ^[[94mRunning pre-run checks^[[0m
^[[36m2021-04-06 21:40:30,740 (DEBUG) wo.core.logging : ^[[95mchecking NGINX configuration …^[[0m
^[[32m2021-04-06 21:40:30,922 (INFO) wo : ^[[92mRunning pre-update checks^[[0m
^[[36m2021-04-06 21:40:30,923 (DEBUG) wo.core.logging : ^[[95mCreating directories: /var/www/sanocorp.com.br/backup/06Apr2021-21-40-28^[[0m
^[[32m2021-04-06 21:40:30,924 (INFO) wo : ^[[94mBackup location : /var/www/sanocorp.com.br/backup/06Apr2021-21-40-28^[[0m
^[[36m2021-04-06 21:40:30,924 (DEBUG) wo.core.logging : ^[[95mCopying file, Source:/etc/nginx/sites-available/sanocorp.com.br, Dest:/var/www/sanocorp.com.br/backup/06Apr2021-21-40-28^[[0m
^[[32m2021-04-06 21:40:30,925 (INFO) wo : ^[[94mBacking up database ^[[0m
^[[36m2021-04-06 21:40:30,926 (DEBUG) wo.core.logging : ^[[95mRunning command: mysqldump --single-transaction sanocorp_com_br_RQVivn4D | zstd -T0 -c> /var/www/sanocorp.com.br/backup/06Apr2$
^[[36m2021-04-06 21:40:30,957 (DEBUG) wo.core.logging : ^[[95mCommand Output: ,
Command Error: Incorrect parameters
Usage :
zstd [args] [FILE(s)] [-o file]*
FILE : a filename
with no FILE, or when FILE is - , read standard input*
Arguments :
- -# : # compression level (1-19, default:3)*
- -d : decompression*
- -D file: use
fileas Dictionary* - -o file: result stored into
file(only if 1 input file)* - -f : overwrite output without prompting*
–rm : remove source file(s) after successful de/compression - -k : preserve source file(s) (default)*
- -h/-H : display help/long help and exit*
mysqldump: Got errno 32 on write
^[[0m
^[[32m2021-04-06 21:40:30,958 (INFO) wo : ^[[94m[^[[0m^[[91mFail^[[94m]^[[0m
^[[36m2021-04-06 21:40:30,958 (DEBUG) wo.core.logging : ^[[95m’mysqldump failed to backup database’^[[0m
^[[32m2021-04-06 21:40:30,959 (INFO) wo : ^[[94m^[[91mCheck the log for details:tail /var/log/wo/wordops.logand please try again^[[0m
Usei o comando com --wpredis para tentar usar o Redis mas ocorre erro semelhante.
