Erro ao criar o primeiro WP Erro no Banco de Dados
Olá Gabriel,
Estou no passo a passo de criar o WordPress em um servidor com WordOps.
No meu primeiro site de WordPress, apareceu o seguinte erro no banco de dados.
File “/opt/wo/lib/python3.11/site-packages/pymysql/connections.py”, line 633, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
sys.exit(main())
File “/opt/wo/lib/python3.11/site-packages/wo/cli/main.py”, line 102, in main
app.run()
File “/opt/wo/lib/python3.11/site-packages/cement/core/foundation.py”, line 882, in run
File “/opt/wo/lib/python3.11/site-packages/cement/core/controller.py”, line 471, in _dispatch
return func()
return func()
File “/opt/wo/lib/python3.11/site-packages/cement/core/controller.py”, line 477, in _dispatch
return func()
File “/opt/wo/lib/python3.11/site-packages/wo/cli/plugins/site_create.py”, line 399, in default
wo_wp_creds = setupwordpress(self, data, vhostonly)
File “/opt/wo/lib/python3.11/site-packages/wo/cli/plugins/site_functions.py”, line 288, in setupwordpress
data = setupdatabase(self, data)
File “/opt/wo/lib/python3.11/site-packages/wo/cli/plugins/site_functions.py”, line 200, in setupdatabase
WOMysql.execute(self, “create database {0}”
File “/opt/wo/lib/python3.11/site-packages/wo/core/mysql.py”, line 71, in execute
connection = WOMysql.connect(self)
File “/opt/wo/lib/python3.11/site-packages/wo/core/mysql.py”, line 34, in connect
connection = pymysql.connect(
File “/opt/wo/lib/python3.11/site-packages/pymysql/connections.py”, line 358, in init
self.connect()
File “/opt/wo/lib/python3.11/site-packages/pymysql/connections.py”, line 711, in connect
raise exc
pymysql.err.OperationalError: (2003, “Can’t connect to MySQL server on ‘localhost’ ([Errno 111] Connection refused)”)
Ontem, durante o dia percebi diversos problemas com a rede de internet em geral. Inclusive o Mercado Livre estava off em alguns momentos.
Isso me leve a acreditar que o servidor, devido a falhas de rede não conseguiu fazer o download e atualização de alguns pacotes necessários para o WordOps.
Por isso, minha primeira recomendação é destruir esse server e tentar novamente com um server novo.
Olá Gabriel,
Tentei fazer a instalação pelo Ubuntu 22 e apareceu o mesmo erro abaixo, igual o erro no Debian.
Start : wo-kernel [OK]
Adding repository for MySQL, please wait…
Adding repository for NGINX, please wait…
Adding repository for PHP, please wait…
Updating apt-cache [OK]
Installing APT packages [OK]
Restarting Nginx [OK]
Configuring Nginx [OK]
Restarting php8.2-fpm [OK]
Configuring php8.2-fpm [OK]
Tuning MySQL configuration [OK]
Restarting mariadb [OK]
Running pre-update checks [OK]
Setting up NGINX configuration [Done]
Setting up webroot [Done]
Downloading WordPress [Done]
Setting up database Traceback (most recent call last):
File “/opt/wo/lib/python3.10/site-packages/pymysql/connections.py”, line 633, in connect
sys.exit(main())
File “/opt/wo/lib/python3.10/site-packages/wo/cli/main.py”, line 102, in main
app.run()
File “/opt/wo/lib/python3.10/site-packages/cement/core/foundation.py”, line 882, in run
File “/opt/wo/lib/python3.10/site-packages/cement/core/controller.py”, line 471, in _dispatch
return func()
return func()
File “/opt/wo/lib/python3.10/site-packages/cement/core/controller.py”, line 477, in _dispatch
return func()
File “/opt/wo/lib/python3.10/site-packages/wo/cli/plugins/site_create.py”, line 399, in default
File “/opt/wo/lib/python3.10/site-packages/wo/cli/plugins/site_functions.py”, line 288, in setupwordpress
File “/opt/wo/lib/python3.10/site-packages/wo/cli/plugins/site_functions.py”, line 200, in setupdatabase
File “/opt/wo/lib/python3.10/site-packages/wo/core/mysql.py”, line 71, in execute
File “/opt/wo/lib/python3.10/site-packages/wo/core/mysql.py”, line 34, in connect
File “/opt/wo/lib/python3.10/site-packages/pymysql/connections.py”, line 358, in init
self.connect()
File “/opt/wo/lib/python3.10/site-packages/pymysql/connections.py”, line 711, in connect
raise exc
root@cloud:~#
Tudo indica ser um erro temporário devido a instabilidades de rede.
Já tentou novamente? Se sim, deu certo?
Você está usando o argumento --wpfc?
Tive o mesmo problema e retirei este argumento e funcionou
Este argumento é para instalar o cache, mas parece que a api está com erro
