Depois de instalar um plugin meu site parou de funcionar
# Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
logs error show
Digest: sha256:f7467469ab9e39c3548d4478e3f416c05b34a0ee58eb6e40b963e562005669cc
Status: Downloaded newer image for discourse/base:2.0.20230313-1023
[docker.io/discourse/base:2.0.20230313-1023](http://docker.io/discourse/base:2.0.20230313-1023)
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: unable to apply apparmor profile: apparmor failed to apply profile: write /proc/self/attr/apparmor/exec: no such file or directory: unknown.
Checking your domain name . . .
Connection to [luxx.com](http://luxx.com/) succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
x86_64 arch detected.
Your Docker installation is not working correctly
See: [Troubleshoot docker installation issues - #18](https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18)
Failed to restart the container.
WARNING:
You have what appear to be non-official plugins.
If you are having trouble, you should disable them and try rebuilding again.
See [discourse/metadata.rb at main · discourse/discourse · GitHub](https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb) for the official list.
Discourse version at [luxx.com](http://luxx.com/): NOT FOUND
Discourse version at localhost: NOT FOUND
