Gabriel, Preciso de ajuda. Criei um subdominio mas não entra no ar. Outros que criei anteriormente estão tudo ok.
Recebí esta mensagem:
Certificate type : subdomain
Validation mode : DNS mode with dns_cf
Issuing SSL cert with acme.sh [OK]
Deploying SSL cert [OK]
Adding HTTPS redirection [OK]
Updating site url with https [OK]
Reloading Nginx [OK]
Congratulations! Successfully Configured SSL on https://refluxo.nuncamais.com.br
sys.exit(main())
File “/opt/wo/lib/python3.7/site-packages/wo/cli/main.py”, line 102, in main
app.run()
File “/opt/wo/lib/python3.7/site-packages/cement/core/foundation.py”, line 882, in run
File “/opt/wo/lib/python3.7/site-packages/cement/core/controller.py”, line 471, in _dispa tch
return func()
return func()
File “/opt/wo/lib/python3.7/site-packages/cement/core/controller.py”, line 477, in _dispa tch
return func()
File “/opt/wo/lib/python3.7/site-packages/wo/cli/plugins/site_create.py”, line 568, in de fault
.format(wo_domain))
File “/opt/wo/lib/python3.7/site-packages/wo/core/git.py”, line 32, in add
status = wogit.status(“-s”)
File “/opt/wo/lib/python3.7/site-packages/sh.py”, line 1566, in call
return RunningCommand(cmd, call_args, stdin, stdout, stderr)
File “/opt/wo/lib/python3.7/site-packages/sh.py”, line 822, in init
self.wait()
File “/opt/wo/lib/python3.7/site-packages/sh.py”, line 879, in wait
self.handle_command_exit_code(exit_code)
File “/opt/wo/lib/python3.7/site-packages/sh.py”, line 905, in handle_command_exit_code
raise exc
sh.ErrorReturnCode_128:
RAN: /usr/bin/git -C /var/www/refluxo.nuncamais.com.br/conf/nginx status -s
STDOUT:
STDERR:
fatal: detected dubious ownership in repository at ‘/var/www/refluxo.nuncamais.com.br/conf/ nginx’
To add an exception for this directory, call:
git config --global --add safe.directory /var/www/refluxo.nuncamais.com.br/conf/ngi nx
e o print do DNS do cloud Flare
O que esta causando este erro?
