Instalação do ngxblocker
Fala Gabriel,
Depois de instalar o ngxblocker para um site no meu servidor (wo site update site.tld --ngxblocker), apareceu uma mensagem imensa que mesmo pesquisando não consegui definir se são erros ou não. Por favor me dá uma luz, tenho instalado Debian 10. Segue abaixo:
sys.exit(main())
File “/opt/wo/lib/python3.7/site-packages/wo/cli/main.py”, line 102, in main
app.run()
File “/opt/wo/lib/python3.7/site-packages/cement/core/foundation.py”, line 882 , in run
File “/opt/wo/lib/python3.7/site-packages/cement/core/controller.py”, line 471 , in _dispatch
return func()
return func()
File “/opt/wo/lib/python3.7/site-packages/cement/core/controller.py”, line 477 , in _dispatch
return func()
File “/opt/wo/lib/python3.7/site-packages/wo/cli/plugins/site_update.py”, line 143, in default
self.doupdatesite(pargs)
File “/opt/wo/lib/python3.7/site-packages/wo/cli/plugins/site_update.py”, line 852, in doupdatesite
if ‘wo_db_name’ in data.keys() and not data[‘wp’]:
KeyError: ‘wp’
root@projetos:~# Traceback (most recent call last):
-bash: syntax error near unexpected token most' root@projetos:~# File "/usr/local/bin/wo", line 8, in <module> -bash: syntax error near unexpected token newline’
root@projetos:~# sys.exit(main())
-bash: syntax error near unexpected token `main’
root@projetos:~# File “/opt/wo/lib/python3.7/site-packages/wo/cli/main.py”, li ne 102, in main
return func()
KeyError: ‘wp’
-bash: File: command not found
root@projetos:~# app.run()
File “/opt/wo/lib/python3.7/site-packages/cement/core/foundation.py”, line 8 82, in run
-bash: syntax error near unexpected token File' root@projetos:~# return_val = self.controller._dispatch() -bash: syntax error near unexpected token (’
root@projetos:~# File “/opt/wo/lib/python3.7/site-packages/cement/core/control ler.py”, line 471, in _dispatch
root@projetos:~# return func()
-bash: syntax error near unexpected token (' root@projetos:~# File "/opt/wo/lib/python3.7/site-packages/cement/core/control ler.py", line 471, in _dispatch -bash: File: command not found root@projetos:~# return func() -bash: syntax error near unexpected token (’
root@projetos:~# File “/opt/wo/lib/python3.7/site-packages/cement/core/control ler.py”, line 477, in _dispatch
-bash: syntax error near unexpected token (' root@projetos:~# File "/opt/wo/lib/python3.7/site-packages/wo/cli/plugins/site _update.py", line 143, in default -bash: File: command not found root@projetos:~# self.doupdatesite(pargs) -bash: syntax error near unexpected token pargs’
root@projetos:~# File “/opt/wo/lib/python3.7/site-packages/wo/cli/plugins/site _update.py”, line 852, in doupdatesite
root@projetos:~# if ‘wo_db_name’ in data.keys() and not data[‘wp’]:
-bash: syntax error near unexpected token `(’
root@projetos:~# KeyError: ‘wp’
-bash: KeyError:: command not found
Esse log tem sido exibido a tempos. Já deveria ter sido corrigido.
Mas mesmo com essa mensagem o ngxblocker é istalado e funciona corretamente.
